Anyone got a carb sync tool that threads into the carb body?
Meaning on the powerjet carbs or possibly any Mikuni, on the bellmouth side or air box side of the carb there is one little pan head screw that is supposed to be removed to affix a sync tool too. The tool should have the metering balls.
Would like some pics to one or a link to one that you currently own and use please. The type that you simply hold to the bellmouth while the engine is running is poor and is not accurate in my opinion.
I believe these fittings are called reversed nipples...someone correct me if I am wrong.
