1995 Polaris XCR 600 Suspension
jasoniowa
Post by jasoniowa »
Does any one know if a skid from a 1996 xcr will fit in the 1995 xcr. The one from the 96 is called an xtra 10 and the 95 is an xc-101. I tried to put the skid from the 96 in and cant get back holes to line up. if i take the xtra 10 rear swing arm off and install the 95 rear swing into the 96 skid it will fit. im not sure if i can run it that way.
My sleds, 1982 Liqufire, 1980 Trailfire, 1977 Sno*jet SST.
Re: 1995 Polaris XCR 600 Suspension
Did you try to untension the rear torsion springs when trying to line up the holes?
ljm
Real Name: Lloyd
Post by ljm »
I'm pretty sure you need to drill new hole to make the xtra 10 work
Several Deere's
Several Kawasaki's
ACSCC #1534
