Mikuni carb
Mikuni carb
I am restoring a '80 Trailfire 440. I took apart the carburetor and the needle is pitted fairly bad. It is a 6F27 needle. After a lot of searching and calling around, I have not found a 6F27 needle. Everyone has told me this needle has been discontinued. Can someone please tell me a good replacement needle for this carb? I know there are charts out there explaining how to measure the needle to determine the sizes to find a fairly close replacement, but I haven't been around these things long enough to feel comfortable making this call on my own. Can someone please help?!
- Real Name: Bob Amber
Re: Mikuni carb
I'll check today and post it here. I'll also check my stock.
Sent from my SPH-L710 using Tapatalk
Re: Mikuni carb
I have a straight used one you can have. Pm me your address
- Real Name: Pat Kennedy
Re: Mikuni carb
Hello! I am looking for a couple 6F27 needle. Have been searching high and low. Wondering if you have any more or know where I could find one. Thanks~
- Platinum_2
- Real Name: Gary
Re: Mikuni carb
Needles rarely need replacing. Check salvage yards. Many will have clean used ones available.
1981 Liquifire
1980 Sportfire
1980 Sportfire
Re: Mikuni carb
A source that I have used several years ago is "Pats Small Engines" http://www.psep.biz/. They stock a lot of Mikuni parts and they have ordered for me what they did not have. May be worth a try. If I remember right, they were located in Minneapolis.
