Liquidator separating crankcase
hounds84lhs
Post by hounds84lhs »
I'm having a little trouble separating the crankcase on my Liquidator. The only easy way to do it that I see is to make a plate that bolts to the engine mount and has pusher screws that would push on the bolts that hold the crankcase together. Any help advice would be appreciated.
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
hounds84lhs
Re: Liquidator separating crankcase
This is a picture of what I was thinking. The orange arrows would be bolts holding to the bottom part of the crankcase. The green arrows would be pusher bolts in the plate. Hopefully someone has an easier idea, otherwise this might be the only option.
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
2 x 4 and a rubber mallet will save you a bunch of time.
hounds84lhs
Maybe I should re-state the question? Is there any trick to splitting the block? This one doesn't seem to want to split? :wall:
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
hounds84lhs
Engineered to perfection, watch for the new crankcase separating tool at a retail outlet near you! :beers;
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
:clap:
