80' Trailfire 340/440 Chaincase
JDFanatic19
Post by JDFanatic19 »
So we bought two JD's last year, didn't use them much last year. We're taking the chaincase apart for the upcoming winter and figured out its scratching the casing. And the tensioner is a made-up one. So i cant find a diagram of the whole chaincase so i can see what parts are missing. Does anyone have a diagram of a 1979-1980 JD Trailfire 340-440 Chaincase?
Dillon Devine
Chatham ON
2 1979 John Deere Trailfire 340's. Also have seized 340 and 440 (later to be rebuilt)
1990 ski-doo safari (Dad's Sled)
Re: 80' Trailfire 340/440 Chaincase
JDFanatic19 wrote:So we bought two JD's last year, didn't use them much last year. We're taking the chaincase apart for the upcoming winter and figured out its scratching the casing. And the tensioner is a made-up one. So i cant find a diagram of the whole chaincase so i can see what parts are missing. Does anyone have a diagram of a 1979-1980 JD Trailfire 340-440 Chaincase?
http://jdpc.deere.com/jdpc/servlet/com. ... ,+Keylines
JDFanatic19
That link you sent me doesnt work
Dillon Devine
Chatham ON
See attachment
That diagram is a little confusing because I don't believe you will have items 9,10,11,12,13. That's the roller tensioner that wasn't normally used on the trailfire.
JDFanatic19
Matt wrote:That diagram is a little confusing because I don't believe you will have items 9,10,11,12,13. That's the roller tensioner that wasn't normally used on the trailfire.
Thanx a bunch. But yea i dont have 9, 10, 11, 12, and 13. It doesnt have a whole for 5 and 6. It has a pin and a slot for a tensioner. The guy i bought this JD off of one made his own up. So i don't know what it looks like. What is number 7?
Dillon Devine
Chatham ON
7 should be your tensioner.
JDFanatic19
Matt wrote:7 should be your tensioner.
7 looks like the tensioner i have. The chain doesn't seem to be tight enough. Its still pretty loose
Dillon Devine
Chatham ON
johnnycyclone
Real Name: Terre
Post by johnnycyclone »
There are different combinations of gears, and chains you can run. I would start by counting the number of teeth on the top and bottom sprocket, and also count the number of links in the chain. You can then compare what you have to what Deere recommends in the service manual. If you have too much slack with the tensioner installed then something is not right.
Terre
JDFanatic19
johnnycyclone wrote:There are different combinations of gears, and chains you can run. I would start by counting the number of teeth on the top and bottom sprocket, and also count the number of links in the chain. You can then compare what you have to what Deere recommends in the service manual. If you have too much slack with the tensioner installed then something is not right.
Terre
The only problem is i dont have a deere manual
Dillon Devine
Chatham ON
johnnycyclone
Real Name: Terre
You can find on line manuals here.
http://www.vintagesnow.com/John_Deere.html
johnnycyclone
Real Name: Terre
If you need any help, just keep asking questions.
Terre
JDFanatic19
johnnycyclone wrote:If you need any help, just keep asking questions.
Terre
Ok, thanx a bunch
Dillon Devine
Chatham ON
