Wanted: 84 Liquifire Flywheel
Steve
Post by Steve »
Need flywheel with ring gear for 84 Liquifire. Noticed magnets came off after removal on the one I own. Would appreciate knowledge on any other models with flywheels that could be swapped. Thanks, Steve
Liquifire84
Re: Wanted: 84 Liquifire Flywheel
Post by Liquifire84 »
Steve,
I believe you can use any of any of the kawasaki flywheels with the ring gear on it. I had to change one out with a similar problem back a few years ago and I used one off a trail and it worked fine for me. But thats my 2ct. Other may now differently.
Brice
ljm
Real Name: Lloyd
Post by ljm »
Just press the ring gear off your flywheel and press it on another one
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Steve
Post by Steve »
Thanks guys. I''ll be able to solve it with your suggestions.
Steve
Liquifried
Post by Liquifried »
I have a couple off 80 Liquifires
74 Evinrude Skimmer 400
82 Trailfire LX
82 Sportfire (Electric Start)
83 Sportfire (Original Owner)
83 Liquifire
84 Sportfire
97 Indy 500 Liquid
1996 Polaris XLT Touring
JD600
Post by JD600 »
Has anyone confirmed that the HSR ignition uses the same flywheel? I thought they were a little different, but could be wrong.
DE
Steve
Post by Steve »
Thanks Dustin,
I'm wondering the same thing. I'm going to try one off an 80 trailfire. It'll be awhile before I reassemble the engine, so if someone got further insight, I'd appreciate it.
Steve
monte44
Post by monte44 »
I am pretty positive the HSR LF used a different flywheel.
I did a conversion many years ago and they are not the same flywheel.
mwking
Post by mwking »
The flywheels and stators for the HSR ignition are different, but if you do a search on the board there was a post by Pete Duncanson (That Girl Racing) a few years back that stated that they would interchange. You can use a later HSR box with an early stator and flywheel and early CDI and coil with a HSR stator and flywheel. Here is the post: http://www.jdsleds.com/community/viewto ... 91&p=42566
Steve
Post by Steve »
Thanks everyone for your help. I'm excited to get the Liquifire together for this season, and this is a great forum. I appreciate a place to go for help where there's a lot of people with a common interest.
Steve
