Wanted - Trailfire Right Spindle
ecardinal
Post by ecardinal »
I need the right side spindle for an 1982 Trailfire. Right side when sitting on the sled. Please let me know what you have.
Eric
69camaro
Real Name: Duane Gjerseth
Re: Wanted - Trailfire Right Spindle
Post by 69camaro »
Pretty sure I have one. I don't have a parts book but I would assume a 79 Trailfire as well as 80 Sportfires use the same spindle. If they work I have one.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
427cobra
Real Name: Eric
Post by 427cobra »
I believe I have one too. I dont think they differ from side to side either...
If Duane cant help you...let me know
smitfire
Real Name: Dustin Smit
Post by smitfire »
They are different from side to side cause the right hand has the steering tie rod. The other difference is the splines.
427cobra
Real Name: Eric
Post by 427cobra »
Spindles are the same side to side. But you are right...the steering linkages are different.
The Liquifires used a finer spline than the Trailfires.
smitfire
Post by smitfire »
427cobra wrote:Spindles are the same side to side. But you are right...the steering linkages are different.
Ok i was thinking steering arm. To early in the morning haha
Accoirding to the parts book, <155,000 used a different one than >155,000.
johnnycyclone
Real Name: Terre
Post by johnnycyclone »
WinnipegStPaul9 wrote:Accoirding to the parts book, <155,000 used a different one than >155,000.
I'm not positive, but the difference is probably the size of the splines, so that would be important to know. The later models had the coarse splines, I think. I know for sure the 83 Liquifire I had, had the coarse splines.
jdrob
Real Name: Rob
Post by jdrob »
Hey guys, DA and Terre are correct the splines are different ! the early models used the fine splines and the later models used a course spline ! :usa:
What he needs according to the manual would be a course spline spindle ! I will check and see if i can help also ! :lol22:
Jdrob
69camaro
Post by 69camaro »
I have one off of a 82 Trailfire too. I just haven't sold any parts off of it yet so if the 79 is different I have the actual 82. PM SENT
75-340/s
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
smitfire
Post by smitfire »
69camaro wrote:I have one off of a 82 Trailfire too. I just haven't sold any parts off of it yet so if the 79 is different I have the actual 82. PM SENT
Duane Are you going to part out the 82?
69camaro
Post by 69camaro »
Yep, the whole thing.
75-340/s
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
smitfire
Post by smitfire »
Pm sent!
