Wanted - Trailfire Right Spindle
I need the right side spindle for an 1982 Trailfire. Right side when sitting on the sled. Please let me know what you have.
Eric
Eric
- 69camaro
- Real Name: Duane Gjerseth
Re: Wanted - Trailfire Right Spindle
Pretty sure I have one. I don't have a parts book but I would assume a 79 Trailfire as well as 80 Sportfires use the same spindle. If they work I have one.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
I believe I have one too. I dont think they differ from side to side either...
If Duane cant help you...let me know
They are different from side to side cause the right hand has the steering tie rod. The other difference is the splines.
Spindles are the same side to side. But you are right...the steering linkages are different.
The Liquifires used a finer spline than the Trailfires.
Ok i was thinking steering arm. To early in the morning haha427cobra wrote:Spindles are the same side to side. But you are right...the steering linkages are different.
Accoirding to the parts book, <155,000 used a different one than >155,000.
- johnnycyclone
- Real Name: Terre
I'm not positive, but the difference is probably the size of the splines, so that would be important to know. The later models had the coarse splines, I think. I know for sure the 83 Liquifire I had, had the coarse splines.WinnipegStPaul9 wrote:Accoirding to the parts book, <155,000 used a different one than >155,000.
- jdrob
- Real Name: Rob
Hey guys, DA and Terre are correct the splines are different ! the early models used the fine splines and the later models used a course spline !
What he needs according to the manual would be a course spline spindle ! I will check and see if i can help also !
Jdrob
- 69camaro
I have one off of a 82 Trailfire too. I just haven't sold any parts off of it yet so if the 79 is different I have the actual 82. PM SENT
75-340/s
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
69camaro wrote:I have one off of a 82 Trailfire too. I just haven't sold any parts off of it yet so if the 79 is different I have the actual 82. PM SENT
Duane Are you going to part out the 82?
- 69camaro
Yep, the whole thing.
75-340/s
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
Pm sent!
