Today I took apart my spare trailfire engine. One cylinder has cast into it 440/2A and the other has just 400 cast into it. The pistons are real close but one does not copletely thru the bore and the head has a copper ring on it where the other does not. which is correct for the trailfire 440 and what did the other cylinder come from?
Trailfire Cylinder casting number?
- Real Name: Lloyd
Re: Trailfire Cylinder casting number?
The 440/2a I THINK is from a Sportfire/Drifter/Intruder engine. I know they use copper head gaskets.
That is strange I did not think the cylinders from a T7 would go on a T1
Lloyd
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
82-84 trailfires use a copper head gasket.
That 400 jug maybe from the old Cat era.
It may have been bored and sleeved for 440.
- jdrob
- Real Name: Rob
I think Todd would be correct. early cat 400. or the possibilty of a later sno jet/kawasaki but i am not aware of any 400cc engines used in the 77' era.
Jdrob
One reason why I am wondering is because I want to buy a gasket set, what set do I buy? I also noticed the keepers on the piston pin are different but that could be from different manufacturers. I am thinking from what your telling me the 440/2A should be correct for the trailfire.
Herd wrote:One reason why I am wondering is because I want to buy a gasket set, what set do I buy? I also noticed the keepers on the piston pin are different but that could be from different manufacturers. I am thinking from what your telling me the 440/2A should be correct for the trailfire.
What year trailfire do you have?
The engine is from a 1982 Trailfire
