Does anyone know if there are aftermarket reed valves that will fit the Kioritz engines?
Has anyone ever experienced reed valve failure? If so can you describe how the sled acted? Is there a way to test them?
Troy
Reed Valve question
- HoosierDeereMan
- Real Name: Troy Miley
Reed Valve question
Re: Reed Valve question
From the service manual
A faulty reed valve can usually be detected by excessive fuel "spit-back" through the carburetor, causing a "popping" noise. Some where I think I read that up to 0.060 hang-open clearance was exceptable. You could try and turn them over.
