Wanted: Spitfire Crank Kawasaki TB340A
81 spitfire
Post by 81 spitfire »
Hey guys,
I am looking for a good used crankshaft that would fit a Kawasaki TB340A. Also is there any chance that a crankshaft from a '79 340 Kohler engine would fit in this motor?
ljm
Real Name: Lloyd
Re: Wanted: Spitfire Crank Kawasaki TB340A
Post by ljm »
I would be surprised if they were anywhere close to fittling.
A crank from a Trailfire engine or any of the T1 series Kawasaki engines should fit.
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
johnnycyclone
Real Name: Terre
Post by johnnycyclone »
A Kohler crank definitely will not work.......Terre
smitfire
Real Name: Dustin Smit
Post by smitfire »
Trailfire and Kawasaki spitfire share the same crank.
I have a Spitfire crank not in a sled. Last I saw it she was boxed up and wrapped in plastic. I will be in NY before Christmas if you are not in a huge hurry, and could send a pic then.
-Joe Rainville
81 spitfire
Thank you everyone for the replies, I figured that the cranks would not be the same but it was worth a shot. Joe I am trying to get one before then, but if I haven't found anything by then I will be contacting you about it.
Thanks again :thinksnow:
sledder670
Post by sledder670 »
I think i have one in a set of cases i will have to check it out works been crazy so send a pm as a reminder.
