Taillight with no brake light
Bardtj
Post by Bardtj »
I have a 1974 JD 300. My running light works, however I have no brake light. Any help?
Re: Taillight with no brake light
Check the bulb first. 1157. Make sure the ground wire is good.
Then look at the brake switch in the grip.
You can unplug the two wire connector behind the dash and jumper the two contacts.
This should light the bulb.
If not check the switch with a ohmmeter at the connector while it is unplugged.
Lever at rest, open curcuit. Lever squeezed, closed curcuit.
Also look at the wire under the seat.
Mice sometimes chew through the wire while removing your foam to play their favorite game... "Stuff The Fan Housing".
Bardtj
Post by Bardtj »
Thank you
JD600
Post by JD600 »
JDT wrote:Mice sometimes chew through the wire while removing your foam to play their favorite game... "Stuff The Fan Housing".
I thought for sure it was "Stuff The airbox"....
DE
Chipmunks are the ones that stuff the airbox silly rabbit.
Viktory2k1
Post by Viktory2k1 »
funny, I have had all those problems. Also a new one, mouse condo under engine cooling cover. So packed, thing woulda overheated in 2 seconds.
Current:
77 John Deere Cyclone 440
98 Yamaha SRX700
Past:
1968 Rupp GT300
1970 Evenrude Bobcat 440
1976 Arctic Cat Cheetah 440
1976 Ski-Doo TN'T Everest 440
1978 Yamaha Exciter 440
1979? Yamaha Enticer 300
1979? Yamaha Enticer 250
1987 Polaris Sprint 340
