1975 600
Re: 1975 600
Is it hitting on both cylinders?
What do the plugs look like after the 15 sec run and die?
hoosierfarm
Re: 1975 600
Post by hoosierfarm »
Yes it does rev smoothly, It just starts and acts totally fine, then dies a few seconds later. You can start, hit the throttle a couple of times and it sounds peppy, then almost as if somebody pinched the fuel line off, just dies. Then you can prime again, starts back up, same thing, then dies. My first thought is it is not getting fuel, but it idles a little to long to just run on the primer fuel.... Plus the other day it idled fine for several minutes and I haven't adjusted anything any differently. The thing that puzzles me is the liquid coming out of the exhaust...? Expecially right after it only starts and idles 15 seconds. Would I need to 'lean' the carb some? Which screw, high speed or low speed would I adjust?
THanks for tips.
hoosierfarm
Re: 1975 600
It has to be hittin on 2 cylinders it is way to peppy not to be...? The plugs look clean maybe a slight light brown, a litttle moist.
Re: 1975 600
Try turning in the low speed needle. The manual says to turn it in while the sled is idling until it smooths out and then begins to studder because it's lean, then back it out a 1/4 turn.
HoosierDeereMan
Real Name: Troy Miley
Re: 1975 600
Post by HoosierDeereMan »
Lot's of good advice! If adjusting the idle mixture doesn't help, I would revisit the carburetor. You mentioned that it idled for 30 or 40 minutes before and won't now. Also has the dreaded black goo leaking from the exhaust joint. Could it be possible that there is something stuck in the needle and seat causing it not to seal off when the float raises? Instead of starving for gas it could be flooding at idle. This might explain the black goo leaking from the exhaust joint. Is your 600 equipped with a tachometer? Idle should be set at 2200 to 2600 RPM.
Troy
Snowslider
Re: 1975 600
Post by Snowslider »
Hey Matt what would it mean if when you rev'ed it it bogged down?
Just trying to learn more.
Thx
Re: 1975 600
Plugged exhuast can make it do that.
So can a bad high speed winding on your stator.
And crankseals....
hoosierfarm
Re: 1975 600
Pretty sure its not plugged exhaust. I can understand the concern about the seals, but why would it idle and run so good and then now won't, I will have anther look at the carb and the lean adjusting. I will see how that goes.
Re: 1975 600
Seals may be 38 years old.
Were intact but brittle when you first started it so they held.
Once engine heated up they fell apart.
They are just waiting for you to take it out for a few mile drive so they can cause your topend to meltdown.
Re: 1975 600
Snowslider wrote:Hey Matt what would it mean if when you rev'ed it it bogged down?
Thx
Just trying to pinpoint if this is an idle only problem or something bigger.
JDT is pushing the crank seal issue because when they fail it can cause a variety of issues, including a blown engine if you choose to ignore them.
Snowslider
Re: 1975 600
How can you tell if your crank seals are shot?
Thx
Re: 1975 600
Snowslider wrote:How can you tell if your crank seals are shot?
Thx
When you change them :angel:
Re: 1975 600
Amen to that.
Thanks DA.
Snowslider
Re: 1975 600
Aaaaaaaaaaall rightty then! lol
Thx
