1982 Liquifire Fuel Pump
Anybody know what the Mukini part number is for the Liquifire fuel pump and/or a JD/Mikuni part number for a rebuild kit? Thanks for the help.
Re: 1982 Liquifire Fuel Pump
- Real Name: Bob Amber
I am sure new breed has them. I think I have bought them before.
Sent from my DROIDX using Tapatalk 2
Fuel pump rebuild kit:
http://newbreedparts.com/index.php?rout ... uct_id=137
New Mikuni fuel pump (however the new version does not have a check valve like the originals so make sure you have a fuel shut-off valve in line)
http://newbreedparts.com/index.php?rout ... uct_id=256
Thanks for all the info. Spent the day digging around the internet and found a website that has the correct kit. The Kawasaki Invaders had the same type of fuel pump and I found it looking under parts for them. Not sure if it's a genuine Mikuni product, but it's alot cheaper than a new pump or the top diaphragm I found on ebay. Here's the link.
http://www.partsreloaded.com/Snowmobile ... nvader-LTD
Maybe one of the moderators could post this on the Parts Sources page.
J man, glad you found what you needed. The moderator of this site also owns the parts site we recommended in New Breed snowmobile parts.
Are you saying the kit I linked to doesn't work?
J Man wrote:Thanks for all the info. Spent the day digging around the internet and found a website that has the correct kit. The Kawasaki Invaders had the same type of fuel pump and I found it looking under parts for them. Not sure if it's a genuine Mikuni product, but it's alot cheaper than a new pump or the top diaphragm I found on ebay. Here's the link.
FYI, that's probally a LLP kit (the 417 part number is the give away). Don't forget to add the missing pin hole in the little flap. Hope you have better luck than I have rebuilding that pump. I have converted all of mine to the standard mikuni pump without the automatic shutoff, and added a shutoff valve.
X2. I've never been able to get a rebuilt 5 plate pump to work properly.nick80lf wrote: I have converted all of mine to the standard mikuni pump without the automatic shutoff, and added a shutoff valve.
DE
