Spitfire wants to go fast
Sprailfire340
Post by Sprailfire340 »
Guys, need some help here...trying to diagnos problem from 200 miles away. My sons are at the cabin with cousins doing a little sledding. Got a 79 spitfire (kohler) converted to mikuni slide carb that goes like hell when you start it. Throttle cable not stuck and slide is moving freely up and down. Idle/air adjustment screws on carb seem to have no affect. Spitty only knows one speed - wide open. Would a stuck choke plunger cause it to immediately redline? A stuck float? Crank seals were replaced last season and it ran great.
:sled: ME
HoosierDeereMan
Real Name: Troy Miley
Re: Spitfire wants to go fast
Post by HoosierDeereMan »
Mitch,
Did the "E" clip fall off the needle?
Troy
My first thought is that it is getting air from somewhere.
Sprailfire340
Nope. They tell me the needle doesn't move in the slide. My best guess is a stuck float at this point.
:sled: ME
HoosierDeereMan
Is this something that had been running and now all the sudden acting up or is this the start up after the conversion?
Is it possible to get the floats installed up side down?
Did the barrel pop out of the slot in the thumb throttle?
Sprailfire340
Barrel didn't pop. Throttle working as designed. Carb conversion was at beginning of last season. Ran great every time out. I just didn't have a chance to go through it as they just pulled it off the trailer for the first ride of the year. I'm going to jump in truck tomorrow morning and try to figure it out for the kid. I'll let you know what I discover. Thanks for the ideas guys.
:sled: ME
lwb140
Real Name: Wade bennett
Post by lwb140 »
im with brian on this one its getting unmetered air from someplace, a stuck float will just cause a gassy mess in the belly pan as the fuel will run out of the carb bowl vent tubes , what about the intake tube being cracked or loose, fuel pump pulse line sucking air, maybe the fuel pump diaphram doing something dumb ? just ideas wade
Viktory2k1
Post by Viktory2k1 »
I can't wait to hear what you find. I'm with the above post as well.
Like carb half off.
Current:
77 John Deere Cyclone 440
98 Yamaha SRX700
Past:
1968 Rupp GT300
1970 Evenrude Bobcat 440
1976 Arctic Cat Cheetah 440
1976 Ski-Doo TN'T Everest 440
1978 Yamaha Exciter 440
1979? Yamaha Enticer 300
1979? Yamaha Enticer 250
1987 Polaris Sprint 340
Cabindweller
Real Name: Jerry Zebro
Post by Cabindweller »
Could be the locking nut on the throttle cable came loose. I had a similar experiance with a Spitfire I just bought not to long ago.
Jerry
bernie tetreault
Post by bernie tetreault »
it is getting air from some wheer between carb @ motor.
Sprailfire340
Wow...This was a good one guys. Over the summer I switched out the original throttle block because the toggle kill switch is easier for the kids to operate. Blocks must not be the same thickness as the throttle cable is too short now. Slide moves up and down freely, but bottoms out at half throttle, thus the go like hell on start-up. Appears one needs to include a trailfire cable to make the conversion work properly. Kids also shelled a recoil on the other spitfire today. If anyone knows where I can buy a rebuild kit I'd appreciate it.
:sled: ME
liquitisplit80
Real Name: Roy
Post by liquitisplit80 »
I bought my kit from car quest. The one here carries lots of aftermarket parts for sleds. The only info on the package is:
Fowler Distributors -Starter pawl kit F11-311.
Not an exact match but it works.
Hope this helps.
'78 Spitfire
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
Still ridin' the New Breed!
