I am looking for the glove box cover on my 80 trailfire and also the hood and tunnel decals for both the 80 and 81 (I do belive they are the same) and also two electric starters for both sleds. Shoot me an email caserules@yahoo.com
Thanks! Ryker Carruthers
Wanted- 80, 81 440 trailfire parts
- Real Name: Ryker Carruthers
When In Doubt, Throttle Out
Re: Wanted- 80, 81 440 trailfire parts
Is there any chance these will fit the kawasaki engines in the 440 trailfires?
http://www.ebay.com/itm/NOS-JOHN-DEERE- ... 20c915ef73
- Real Name: Lloyd
not likely.
There are often starters for the Kawasaki engines on Ebay.
they should be alot more common because they are used on alot more sleds ( Early Arctic Cat, Kawasaki, and late Deere's)
Lloyd
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
Just a note here.
When looking for starters remember that there at CW and CCW rotation ones that look the same.
Where they mount makes the difference. Ones that drive a ring gear on the clutch turn oppsoite of the flywheel ring gear units.
And as they only have one terminal you can not reverse rotation.
