Put this out there back in the summer. My cyclone chain case has a slow leak. Running it some this winter I have now determined it is the back cork gasket. Slow weekend for me so I am thinking about replacing it on my own. Looks like some bolts etc to pull everything out to get to it. I have several new cork gaskets and yes everyone warned to check fitment. So before I tear into it, is there more to it than it appears, should I be cautious of anything etc? Does it require any special tools other than wrenches and skinned knuckles?
Thanks for the help for a novice mechanic.
Leaky Chain Case
- jdsledsrgr8
- Real Name: Matt Gabler
Leaky Chain Case
Mt. Horeb WI
1976 Liquidator
1976 Liquidator Clone
1978 Liquifire 440
1976 Liquidator
1978 Liquifire 440
Re: Leaky Chain Case
Required Tools:jdsledsrgr8 wrote:Put this out there back in the summer. My cyclone chain case has a slow leak. Running it some this winter I have now determined it is the back cork gasket. Slow weekend for me so I am thinking about replacing it on my own. Looks like some bolts etc to pull everything out to get to it. I have several new cork gaskets and yes everyone warned to check fitment. So before I tear into it, is there more to it than it appears, should I be cautious of anything etc? Does it require any special tools other than wrenches and skinned knuckles?
service manual, you need to remove the driveshaft in order to replace any of the worn parts. Besides a bad cork gasket, I would replace the large "O" ring that is around the bearing, sandwiched between the bearing flangettes, JD part # U42111 which is still available.
it does require a large can of patience , the bearing bolts/nuts are tough to get to on the back side up insde the tunnel ,but the job is pretty straight forward and im sure you can accomplish the task at hand !! wadejdsledsrgr8 wrote:Put this out there back in the summer. My cyclone chain case has a slow leak. Running it some this winter I have now determined it is the back cork gasket. Slow weekend for me so I am thinking about replacing it on my own. Looks like some bolts etc to pull everything out to get to it. I have several new cork gaskets and yes everyone warned to check fitment. So before I tear into it, is there more to it than it appears, should I be cautious of anything etc? Does it require any special tools other than wrenches and skinned knuckles?
Might want to do the bearings too while your in there. Since it is a pain in the butt to do.
