1978 Liquifire Cross Shafts
boaski
Post by boaski »
I'm trying to get done with a 78 Liquifire that I've been working on at my usual glacial pace. The rear suspension had no movement so I dropped it out. I had hoped that it would be something simple, but both cross shafts are frozen tight. Before I do something stupid I need to see if anyone has found a good way to get aluminum shafts out of steel tubes...
lwb140
Real Name: Wade bennett
Re: 1978 Liquifire Cross Shafts
Post by lwb140 »
Muratic acid Is the best way I've found then have new shafts made , wade
lwb140 wrote:Muratic acid Is the best way I've found then have new shafts made , wade
X2
While I don't disagree, there's more than "one way to skin a cat" and somewhere on this website are the other ways. I just don't know where so you'll have to search. Just plan on having new shafts made, that will at least make you quit worrying about saving them.
lwb140
Post by lwb140 »
i like the acid deal because it seems like no matter what if i try and get the aluminum shaft out i end up damaging the suspension arm and then i am in need of both parts !! i think i may have an extra set of shafts if you need them thanks wade
Here are some of the earlier posts.
http://www.jdsleds.com/community/viewto ... aft#p92088
boaski
Post by boaski »
Thanks for the input! I had thought about using heat, but was afraid of the results listed in the last post. I'm going to try the muratic acid method & see what happens. I had already figured I's have to make new shafts. I may even have some shafts laying here from a previous sled repair.
Thanks again for the responses.
I've gotten several of them out before without destroying them, with heat, a bolt threaded into the end of the shaft to hit, and a hammer.
lwb140
Post by lwb140 »
Matt is right , I think we are the doomsday Crüe that have had ones that won't budge at all , but like Matt says some of them will come out with a little love and finesse
