Spitfire CDI?
81 spitfire
Spitfire CDI?
Post by 81 spitfire »
I am having troubles keeping my 80 spitfire running. It will start fine and I can get it to rev up some of the time and then it just dies. I have tried two different clean carbs and the problem is the same. The engine has all new gaskets and seals, fuel lines, fuel pump, and 125 psi on both sides. I don't believe it is fuel related because I bypasses the pump by adding a gravity fed tank above the air box for testing and there were no noticeable results.
Could this be cause by a bad CDI box that is giving out intermittent spark? If so I have done some searching for a replacement as I do not have one to swap out for testing, and cannot seem to find one that says it is specifically for a spitfire. I can find one for the 78-79 spits, but assume that will not work with the kawasaki motor. I have also found them for trailfires from 80-82. Would the one from a TF work?
Here is the link for the site that I found them on
http://www.psep.biz/store/john_deere_sn ... _boxes.htm
Re: Spitfire CDI?
Sounds like a bad CDI to me.
Somewhat common to see it idle fine and drop dead on any throttle appliction when the CDI is bad.
liquitisplit80
Real Name: Roy
Re: Spitfire CDI?
Post by liquitisplit80 »
81 spitfire wrote: Would the one from a TF work?
No, they are completely different and mount on different sides.
'78 Spitfire
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
Still ridin' the New Breed!
81 spitfire
Re: Spitfire CDI?
Are there any ones that would work for my 80 spit? I cannot seem to find anything anywhere for the spit. Are there any from any other models that would work?
jdrob
Real Name: Rob
Re: Spitfire CDI?
Post by jdrob »
81 spitty Hey the coil/cdi unit is the same on 1980-82 spitfires, some 82-84 trailfires and 82-84 snowfires. The main thing you need to check on the trailfires your finding are do they have an external cdi unit bolted to the fan housing ? If there is none then the coil/cdi unit will work on your spitfire. I hope this helps ! Keep checking ebay they show up sometimes there ! :usa:
Jdrob
jdrob
Real Name: Rob
Re: Spitfire CDI?
Post by jdrob »
81spitfire I sent you a PM thanks !
Jdrob
