Can someone tell me which power bloc to use on a kohler 295 2ax i would like to do some more research on it but am unsure what to look at as all i seem to find are power blocs that are for straight shafts with a key way and not a 30 mm tapper. i just burnt my 2nd last set of used sals liners, three sleds one clutch isn't working for me,
I saw some-ware that a 102c would fit on a kohler 295 2ax but i don't know if i need to change the inner. i have a 102c but i don't want to hurt a motor by doing some thing wrong and wreck my sleds.
jd 300 clutch
Re: jd 300 clutch
Sorry for the delay in posting pics.
You tune the clutch by adding or removing weight from the clutch, less weight gives you more RPM. I needed more weight after this pic was taken so I used steel washers to add some. Use a scale though ad there is a fair difference between them and you want close to the same weight in each puck. The engagement is tuned by the spring, I have a list somewhere I will see if I can dig it up. They come in both 25 mm and 30 mm tapers so you have to make sure you get the correct one.
