High Idle
Danzig
Real Name: Paul File
High Idle
Post by Danzig »
Guys..
I have this 82 Liquifire running, however the idle just will not setting down, its consistently at 3000 or more and will climb to 4000. I am running it with the air box off...never had this problem before. I just put new crank seals in it. The only thing that is eating at me it the timing mark on the stator, I set it exactly where it was when I took it apart and that was a little advanced or counterclockwise of the mark or seam on the case halves. I have the idle screws backed out so far they could fall out of the carbs.
I am thinking I have an air leak...
open for thoughts
smitfire
Real Name: Dustin Smit
Re: High Idle
Post by smitfire »
How are the cables set just on top of the carbs?
Re: High Idle
X 2
lwb140
Real Name: Wade bennett
Re: High Idle
Post by lwb140 »
i have a 77 that had this problem , when i started it ,it would idle at 2000 or whatever , the longer it ran the faster is idled , wouldnt idle down i finally installed a different set of carbs and it ran perfect , never did figure out what was wrong with them this thing drove me crazy i tried everything on it wade
Danzig
Re: High Idle
Post by Danzig »
elaborate on how they are set ?
Danzig
Re: High Idle
Post by Danzig »
I guess I could back them all the way off and go from there, never thought of that till now. Slides are closed enough in my opinion, but...
Re: High Idle
Are the slides bottomed out inside the carb?
Re: High Idle
Recently had the same problem with the Cross Country. Problem was slides were too high. Also, check throttle cable routing to make certain that's not the problem.
mwking
Re: High Idle
Post by mwking »
A really quick check to make sure the cables aren't too tight and the slides are bottoming out is just to give the throttle a quick flip when the engine isn't running. When the slides hit the idle adjustment screw there is a real metalic click you won't hear if the cables are bottoming out first.
Danzig
Re: High Idle
Post by Danzig »
I know that metallic knock and I can hear it on both carbs, screws backed out no knock. I am very aware of the cable routing with the dash up/dash down, it doesnt matter, pulled on the choke plungers thinking one may have been hanging up, no such thing. I will take the adjustment out of the cables and start there. You know, I was trying to feel the slides move up and down with the idle adjustment screws and wasnt really satisfied with the performance, I couldnt really feel the slides moving in any direction. I even pulled the slides out looking for issues with the springs. I will be taking the adjustment out of the cables and start there. I will report my findings.
Danzig
Re: High Idle
Post by Danzig »
Cables were not set correctly...it is now !!
:sled:
go to the resto on this sled for pics !!
Re: High Idle
Way to go...
PolCat
Re: High Idle
Post by PolCat »
Which cables? Does that mean the idle is back down?
Danzig
Re: High Idle
Post by Danzig »
Idle is back down to 1800
cablse leading into the top of each carb
PolCat
Re: High Idle
Post by PolCat »
Glad you found it :clap:
