440 trailfire clutching
That Girl Racing
Real Name: Peter
Re: 440 trailfire clutching
Post by That Girl Racing »
I am going to stick to my my guns. Clutching
Ryker Carruthers
Real Name: Ryker Carruthers
Post by Ryker Carruthers »
That Girl Racing wrote:I am going to stick to my my guns. Clutching
I cant say you are wrong but I did have everything adjusted correctly. The spring in the secondary same as dads and primary the same weights and spring. And the belt was out of the secondary 1/16" and deflection was about 1.5". It got even worse the more I rode it so I called ken and after that and he asked if it was losing compression as it got hot and it was. So I have some extra cylinders Ill drop in and hope that fixes it.
Ryker Carruthers
When In Doubt, Throttle Out
That Girl Racing
Real Name: Peter
How does it start?
Ryker Carruthers
It starts great. Good compression cold. Not warm tho
luvzvintage
Post by luvzvintage »
in reply to johnnycyclone reference to the JD manual and Comet's manual for spring and weights, i have nice comet's restored with one of each configuration. I've found the purple spring/B weights (same as Liquifire) clutch too really wake up my Trailfire 440 both on takeoff and acceleration, however, clutch engagement is around 3600 rpm and top end seem to lack some. With the silver spring/U weights (same as Sport?) the overall performance is ok, alot flatter with maybe a bit more top end, with engagement rpm at around 2200 - 2400.
comet has more than one silver spring...is this the difference between the trail 440 and sporty's clutching. If not, they're the same clutch?!?
Ryker Carruthers
The Sporty has F weights and silver spring. Trailfire has Silver spring and U weights. Dads has this and the primary engages at 3800 rpm and the sporty at about 4200
luvzvintage
the JD book lists the sporty having U weights. F weights were run in the 76 liquifire comet i believe.
Ryker Carruthers
Hmm... Maybe I do have the wrong weights in. But that wouldnt explain what it was doing.
Ryker Carruthers
Back at this again... I found the problem. Blew the mag side bearing cage apart. Loss of power due to excessive friction. I now have a sportfire engine mounted, need to adjust some things. The exhaust is to far forward and I cant the hood on. Got it running anyway. Better throttle response. Now I have a liquifire I hope I don't have to fight with like this.
thanks to all those that were helping me out!
