I made an engine pressure tester tonight. I think it will work quite well. I will post up some pics for all to see and bash me on if need be . I have read Harleys post in the FAQ about this procedure.
One question:
How much air pressure will the crank seals and middle seal hold before failing?
Second question:
7psi is very little and one bump or (oops) of the flow control valve on the tester may end up in severe problems correct?
Engine Pressure testing
- Danzig
- Real Name: Paul File
Paul,
Don't go more than 15 psi !!
- Danzig
Yes, it does but it doesnt read in single digits, it reads from 20 psi on up. I have a gauge on this tool I made that the max is 30psi.
