JDX8 Carb Air Horn or Air Box
- Real Name: Howard Olson
I have a 73 JDX8 that I just bought and am getting running. The carb has a horn on it instead of an airbox. Did any of the early JDX8s come with just a horn instead of an airbox. Also, the carb is stamped WD-5. I thought WDA-34 was standard. Maybe a different carb than the original?
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Re: JDX8 Carb Air Horn or Air Box
I would say the carb has been switched. WDA-34 was original with the air box and hose.
If you decide to get the original setup back, go with the '74-'75 X8 carb, the WRA-31, leaner mid-range is what I've been told.
Photo of the air box and hose on the Wife's 340 beater ( with anti-mouse screen )
