Clutch torque specs
Clutch torque specs
Just replaced seals on 440 motor and was wondering what the torque specs are for the clutch bolt.
Thanks!
Thanks!
1976 cyclone 440
2003 firecat F7
2005 Sabercat 600
2003 firecat F7
2005 Sabercat 600
Re: Clutch torque specs
On the mid mounts it was 50 ft/lbs ( Comet )
Sorry to ask new to these sleds mid mounts? I'm guessing it is a comet I saw it in a service manual I can't locate again.400brian wrote:On the mid mounts it was 50 ft/lbs ( Comet )
1976 cyclone 440
2003 firecat F7
2005 Sabercat 600
2003 firecat F7
2005 Sabercat 600
Mid-mount is a term we use to reference JD sleds built from '72 - '75. The engine in these was located on top of the tunnel, right in front of the driver.
If you are putting the clutch back on a Cyclone, I imagine you have a Comet clutch, and the retaining bolt should be torqued to 50 ft/lbs. The clutch should be put on the crank with both surfaces clean and dry.
Ok thanks for the explanation mine is a 76 cyclone 44 50 ft/lbs still good?
1976 cyclone 440
2003 firecat F7
2005 Sabercat 600
2003 firecat F7
2005 Sabercat 600
Yes, 50 ft/lbs is correct. Here is a link to an online service manual. You will find the torque specs and other info.
http://www.vintagesnow.com/John_Deere_f ... one_SM.pdf
I have that manual harley i couldnt find the clutch bolt specs in it though. i looked a few times.
1976 cyclone 440
2003 firecat F7
2005 Sabercat 600
2003 firecat F7
2005 Sabercat 600
Page 179 of the PDF or Service Manual 50 - 10- 7smithw44 wrote:I have that manual harley i couldnt find the clutch bolt specs in it though. i looked a few times.
Dumb question. How do you hold clutch (102c) to torque bolt.
Use to clutches that do not have cover on them so you slide something through clutch to hold it. Service manual shows cover off and a tool to hold but don't see how that would work.
18 and counting
first thing, leave the old tin clutch cover off. It was deleted in 76. Use a tool like this to hold the clutch.
Was wondering why some had the cover on and some did not. Easy to hold and torque with cover off.
Thanks for the help.
18 and counting
