KEC400/21 pistons
KEC400/21 pistons
What is the standard piston size for a KEC400/21 engine. I think its out of a 74 JDX6. Ordered pistons and was sent two different size pistons.
KEC400/21 pistons
I looked in the specs section on the home page.
'74 X6 is listed as having a 63mm bore.
Re: KEC400/21 pistons
i had 63mm std pistons on my 1975 jd 800!!!!!. how does this work??
The bottoms of the CCW engines are all the same.
The tops are different: ie heads, cylinders and pistons.
Someone switched them around in the past. They put 400 top on a 440 bottom.
I have even seen a 440 top on one side and 400 top on the other. And it was a running engine.
thank you jdt.
