295s motor
deere abby
295s motor
Post by deere abby »
just wondering......... is the 295s motor anything like the 75 300 motor.will any parts interchange?.kioritz and kohler same?pistons different?thanks in advance,Earl
75rat
295s motor
Post by 75rat »
Sorry Earl, they're totally different animals. However, it sure seems the Kohler parts are much easier to find (maybe because I'm always looking for 295/S parts). Good luck....
Jim
GreenSpeed
295s motor
Post by GreenSpeed »
Earl,
The 295/s engine was used only in that sled and most of the parts are unique to the engine. Only some general Kioritz and CCW parts will work on it (fan parts, etc). Kioritz engines were Japaneese based, whereas Kohlers were from Canada (US based Company though). So tell us about your 295/s... owned it long? Condition? Good luck!
deere abby
295s motor
i have two 295s both pretty good shape.belly pans almost perfect on both.one has airbox.both have twin tanks.no aluminum skis though,on either.one has extra hood vent added.where can i find more parts and info?thanks,Earl p.s. had one a month the other for about three months.
GreenSpeed
295s motor
Earl,
I wish I knew where to go for parts. Parts for these are hard to come by because they are pretty unique. You may end up combining the tow you have!? Just keep looking and you may stumble across some. As for info, what are you looking for? I'd say look for an operator's manual, parts book and service manual as they are pretty good sources.
deere abby
295s motor
thanks,i hope to keep them both running.i would like some spare parts.pistons and rings would be nice.are the belt guards ,tracks,or airboxes the same as anything else, Earl
JDXspec
Real Name: Dustin
295s motor
Post by JDXspec »
The 295/s is pretty much the same as any JDX except When it comes to the eng almost nothing interchanges with a more common sled. Track are the same as a 74 and up JDX, 76-78 liquifires and cyclones. Rings for this eng can be found but pistons are hard to come by.
deere abby
295s motor
rings can be found, cool.where can i look.everyone says look for poorly listed items on ebay.i never have any luck.let me in on the secret
:D ,Earl
JDXspec
Real Name: Dustin
295s motor
Post by JDXspec »
DKtrader had some on ebay awhile back. Parts normally are few and far between on ebay but there are deals to found.
speedy295
295s motor
Post by speedy295 »
hey guys
cranks from a 440/5 will fit them, and work.
deere abby
295s motor
really, cool
B) any other info?
speedy295
295s motor
Post by speedy295 »
well everything from the /1,2,3,4,5 morots will physically bolt up, and can be made to work. Mine has worn pistons and cylinders so it may get a set of 440/5 jugs that are brought to 295/rs2 port specs, i'll post more when i get home from break and can look at stuff better
PRRT1MAN
295s motor
Post by PRRT1MAN »
Deere Abby,
I have some parts for a 295S. What do you need? e-mail me
SamV
