in need if some 1983 liquifire information
awm
Post by awm »
hello all, im new to the john deere scene. i recently picked up a 1983 liquifire to oval race. what is the max rpm theese motors should turn in stock form? has anyone ever tried changing the jackshaft and using arctic cat clutches? any input would be great! thanks
Re: in need if some 1983 liquifire information
The 80 to 84 liquifires came from the factory with rev limiters that prevented them from reving over 9,000 rpm. On an 83 its the small black box mounted to the bottom side of the dash. The engine will run fine with the 3 pin connector unplugged (just no limited RPM).
awm
Post by awm »
thanks, what i need is the maximum rpm to hit with out going past the power band and over reving the engine when i go to set up my clutching. are you saying this is a 9,000 rpm engine in stock form?
Check out the 1982 Fine Tune manual over at Vintagesnow.com, it should be able to help you: http://www.vintagesnow.com/John_Deere_f ... neTune.pdf.
Also search for posts on here by user "That Girl Racing" and you will probably find a ton of useful info.
awm
Post by awm »
thanks matt
jdrob
Real Name: Rob
Post by jdrob »
Andy So nice to see you on here. These guys have a wealth of information and knowledge. Glad to meet you at boonville and purchase some parts from you. :usa: :usa: Can't wait to see some pics of the 83' in race form. :popcorn: Jdrob
Jdrob
schavejdsnow
Real Name: John
Post by schavejdsnow »
Hi Andy
Glad to have meet you in Boonville . I'm not that far away . If you need anything you got my number just call .Can't wait to see the sled . Good luck with the build .
72 400/500
73 500 one Dad bought new
74 300/295s
75 800/340s
76 340 LIq
78 Liq 340/cc/Spitfire
80 Liq/Sport
81 Liq
82 Liq/Sport/Sprint/Snow/Spit,
83 Liq/Sport/Trail/Sprint/Snow
84 Liqx3/Sportx3/Trailx3/Sprintx3/Snowx2
Hello Andy,
The 80-84 Liquifire generally tops out about 8,200 in stock form, but power is falling off after 7,800 rpm or so. The HSR (High Speed Retard) ignition the 82-84's came with give you much better low end than the 80-81 versions.
I hope this helps, and good luck with your sled.
-Joe Rainville
awm
Post by awm »
hey guys, it was great meeting you also. here's the latest (sorry no pics yet) the sleds been striped and the next step is the carwash. after that its time to get the angle grinder out, most of the bellypan sheet metal will be removed except for a "frame" so I have something to rivet the new aluminum pan to I fabricated. im doing this to get the weight down. its a very heavy chassis. ill try to get some pictures as I go.........
jdrob
Real Name: Rob
Post by jdrob »
That's great to hear Andy. Glad you are making progress.
Sent from my DROID4 using Tapatalk 2
Jdrob
