I need 2 ( new) or almost new flanges that attach the carb to the motor. Needs to fit a 81 Liquifire. I tried newbreedparts but not in stock until the fall.
WTB- Rubber Carb Mounting Flanges
Re: WTB- Rubber Carb Mounting Flanges
If you want to try the cheaper Parts Unlimited ones...denniskirk.com should have them.
If you can get the Mikuni brand part number from Matt. Just search the p/n and you'll find someone that sells them.
Hello Matt...don't know who that is but maybe he will stop in to say hello
- Real Name: Lloyd
Matt is the caretaker of this site and the owner of Newbreed parts.
I would really encourage you to get the Mikuni carb boots. They are much better
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
This is the genuine Mikuni version, which I do have in stock: http://www.newbreedparts.com/newbreed/i ... uct_id=204
Thanks Matt!! I guess I will be getting those genuine ones but man they sure cost more $$$, They were sure proud of those suckers.
- Real Name: Lloyd
They are worth every penny.
I have melted more than one engine because of the aftermarket ones
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
Don't mess with the aftermarket flanges. Good ones are way cheaper than engine parts.
X2AirborneX4Special wrote:Don't mess with the aftermarket flanges. Good ones are way cheaper than engine parts.
To give you a heads up, both the aftermarket and Mikuni flanges are shorter than the original Deere flanges. This makes it much easier to get the air box installed. I use the genuine mikuni flanges.
pwgsx, if you haven't already discovered it, $$$$$ and vintage sleds go hand in hand. And it only costs cents more to go first class.
Indeed lol!!! Chive OnWinnipegStPaul9 wrote:pwgsx, if you haven't already discovered it, $$$$$ and vintage sleds go hand in hand. And it only costs cents more to go first class.
