78 Rear Suspension Shafts
VintageCatMan
Real Name: Nick Freatman
Post by VintageCatMan »
Anybody repoping the shafts for the 78 skids? Looking to finish up some of my half finished projects. Thanks.
Nick Freatman
Nick Freatman
Re: 78 Rear Suspension Shafts
Nick, are you referring to the inside shafts with the threaded holes? If so, I just have them reproduced here in a local shop.
VintageCatMan
Yes I am Don. They are the ones that are always stuck in the arms, right? These are just for the stock skid, not the cross country? Thanks.
Nick Freatman
Nick Freatman
Nick, can you grab some measurements on those shafts? I might be able to help.
Nick, I have the same shafts in everything, not just race sleds. Keep it simple is my motto. Take Matt up on his offer, you won't regret it. Hope things are well looking forward to seeing you one of these days. I'll be your way first of August but in Canada.
VintageCatMan
Matt, I will grab some dimensions this week. Thanks.
Nick Freatman
Nick Freatman
VintageCatMan
Talked to matt this weekend. How much interest is there in get a full set of shafts for the whole suspension repoped? Would you want it in alum again or should they be made out of steel? Lets hear it guys, whats you opinions.
Nick Freatman
Nick Freatman
I make my own and always use Stainless Steel stock.
JD600
Post by JD600 »
The ones we have machined ourselves, (in the drill press) we have made out of aluminum simply because its easier for us to work with. The ones i have machined at the shop i have made out of mild steel. A good coat of wheel bearing grease prior to installation, and i know these won't be a problem for a long time.
DE
