Need a few parts for my 80 liquifire
Ryker Carruthers
Real Name: Ryker Carruthers
Post by Ryker Carruthers »
Hey guys,
Anyone have a set of bumper bolts they would be willing to part with? I am in need of two powerjet kits too. A hood would be great but I can get along with this one for now, the rear left corner is pretty beat up. And a dash panel.
Got this from a friend in town that works in the john deere dealership, It runs but I need to get the airbox from his son in st. louis. This sled used to be raced on the mississippi. Studded track, racing pipes. aluminum short windshield. Has 2000 some miles. Needs rings and seals. I also need springs for the exhaust pipes. 8 total. and handlebar grips and kill and dimmer switch would be great.
Thanks, Ryker
When In Doubt, Throttle Out
Re: Need a few parts for my 80 liquifire
Ryker,
I have bumper bolts here in TX. Drop me a line at joerainville@hotmail.com or call 585-406-4593 cell evenings.
smitfire
Real Name: Dustin Smit
Post by smitfire »
I have about a half of dozen hoods, I have a good dash, kill switch and dimmer switch
Ryker Carruthers wrote:Hey guys,
Thanks, Ryker
At Newbreedparts.com I have the seals (and full gasket set), exhaust springs, handlebar grips, and I can order the Mikuni powerjet kits (you have non-PJ carbs? What size?)
Ryker Carruthers
Matt wrote: At Newbreedparts.com I have the seals (and full gasket set), exhaust springs, handlebar grips, and I can order the Mikuni powerjet kits (you have non-PJ carbs? What size?)
Yes I have non powerjet carbs, They were on there originally but were removed when it was in Illinois. I am not sure what size they are? I would say they are stock, what do you measure to determine size? I dont think stock exhaust springs are going to work. If I cant get some that fit at the hardware store I will just turn some on the lathe. I will be placing an order at newbreedparts soon. Not sure if I need the seals now. Pulled the clutch and the seal looks new, not like the japanese ones I pulled out of my trailfires.
Ryker
