1980 JD Liquifire by SnowKat79
Re: 1980 JD Liquifire by SnowKat79
Square back skis, look like early 70's Cat skis.
Tail edge looks worn trough also.
snowkat79
Post by snowkat79 »
Kinda figured they werent right..... Thanks Todd.
snowkat79
Post by snowkat79 »
having some trouble getting the top coolant pipe off. bolts are not cooperating, er at least one isnt! it turns a little, and then feels like it could twist off :?
going sandblast the exhaust, and repaint.
snowkat79
Post by snowkat79 »
Is there anything on the oil injection pump that I need to go through or check before putting this engine back in service?
There is a testing procedure for the oil pump in the service manual. It's available on vintagesnow.com if you don't have one.
snowkat79
Post by snowkat79 »
Thanks Matt!
snowkat79
Post by snowkat79 »
Got the exhaust repainted with CAT Hi-Temp muffler paint...pics to come soon
Also, got the lower collant pipe blasted clean, and sprayed in a clear laquer. I will get pics of that too.
Danzig
Real Name: Paul File
Post by Danzig »
if you painted clear on aluminum that gets hot you may hate it, we did this on a motorcycle engine and the stuff turned brown and flaked off in little pieces, looked like it had a sun burn that was peeling........... :think:
snowkat79
Post by snowkat79 »
Danzig wrote:if you painted clear on aluminum that gets hot you may hate it, we did this on a motorcycle engine and the stuff turned brown and flaked off in little pieces, looked like it had a sun burn that was peeling........... :think:
I will keep that in mind. I guess, worst case scenario....I have to re blast those parts.
