Spring & summer 1973 Chaparral FB SS GD Clone project
This is my summer project that I started in Mo. in the spring, & then mocked it up ( just the tunnel, engine, pan & hood ) in MN. so it could be taken to our engine builder in Little Falls MN. so when he gets our other 650 Chap motor ( I'm calling this a motor cuz it'll be faster than an engine, LOL ) built & dyno'd with the dyno pipes he can then place them under the hood, this project I hope to have done for next summers grass drags with Tucker as driver..
Grumpy
another of Front of Chassis with modified Grass Dragger front sub, jackshaft, & brake installed
Front of Chassis with modified Grass Dragger front sub, jackshaft installed
Tunnel with engine installed
started with a 72 Chap SS tunnel, this is the OEM location of the front drive shaft area
after the existing tunnel area was cut to start modifying the existing front drive area to accept the 7-3/4 drivers I'm going to use..
Re: Spring & summer 1973 Chaparral FB SS GD Clone project
2nd bunch of Pics
mocked up with the back part of the chaincase I designed
Jackshaft & brackets ( can you guess which JD sled the brackets came off of?
brake bracket, juice brake, & rotor
3rd set
reinforcement to the tunnel after lowering the front driver bearings
modified bearing placement looking from the inside of the tunnel out towards the chaincase
modified bearing placement in tunnel so 7-3/4" drivers can be used
Front end with the pan, Aluminum spindles & steering arms, engine & just a set of old handle bars so I can make sure everything fits in the right places
4th set
OEM left foot rest will be removed to accept modified one
mounting the hood at Chris's
OEM right foot rest will be removed to accept modified one
more reinforcement
more reinforcement
more reinforcement
more reinforcement
5th set
1-1/4" Titanium Hex shaft
7-3/4" drivers
7-3/4" drivers
center 2 of the Whal drivers mounted on Custom built ( by Industrial machine & gear, Lee's Summit Mo. ) Titanium Hex Shaft, I still have to install the outside 2 drivers.
another of the mock-up before the sled was taken to Little Falls MN.
hood mounted, Note Custom Built Chrome Molly Handle Bars
6th set
the track were going to use ( complast grass track )
I hope I have enough to last a season??
width of the wheels
width of the wheels
Custom repopped OEM style Chap Grasser wheels, 5"
another or the drive shaft, guess I didn't take any of the Titanium Jackshaft??
Very unique project there Kenny.
Two questions...
What is the output of the "motor" as pictured?
That track has four sets of drive lugs?
Todd,
The 650 Chap 3 cyl Free Airs were rated a 127 HP, 440 Triple Free Airs was rated at 90 HP in 72-73 but not many had that much, I did hear a story about the Chap Factory pulling over 130 out of one of there 650 Free Airs. not sure how much there 440 & 650 Liquid Triples pulled? I do know that the 650 Liquid Triples had so much power that they were snapping off the mounting tabs on the cyl's, so the teams that had the liquids had to redo the cyl's & heads so they could use long crankcase to cyl stud bolts that came up all the way through the heads to hold the cyl's in place..
We are having that done to our 650 Free Air motor so we don't have any problems, Motor/Engine parts are getting to hard to find to start destroying them. Even though I do have a few motor parts laying around.... :silenced:
Scott at HEWTEC is also building us a Fireplug CDI for this sled also, hopefully we will be able to try the surface gap plugs then to see if we get any advantage??
The track has 2 double rows of drive cogs in the middle inside & a row of single drive lugs on each of the outsides, 6 rows total, size is 15 X 121 X 2:52 pitch.
Not sure which drive clutches We'll be using but we have quit a selection to choose from.
Comet 102C, 108EXP, HRP Quad Cam billet Clutch, or Quick-Shift Magnum ( a remake of the old Duclo clutch's ).. We'll probably us a Polaris driven, but I'm sure we'll be testing others.
Grumpy
80spitfire
Real Name: Brian Kottke
Post by 80spitfire »
Very cool project Kenny. I remember seeing it in the back of your truck in Owatonna and all I can say is wow that's a cool project. Btw guys, that titanium axle is killer in person!
-Brian
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
With that much grunt I can see the need for the extra drivers. :silenced:
Looking great so far Grumpy. :beers;
Todd, :drool: I'm hoping that with all the motor mods once completed & on the dyno & with custom pipes this puts out close to about a third more HP :think:
