WTB M67790 & M67157 Suspension Pins LF/SF
Liquifried
Post by Liquifried »
Looking for M67790 & M67157 Suspension Pins.
These are the shafts for the front swing arm that holds the front springs and the upper shaft on the rear swing arm. The rear is aluminum and the front is steel. Both are same diamer/threading. I could use 2 of each or 4 steel. If someone has machined, repops with proper tap/die, that would be great.
74 Evinrude Skimmer 400
82 Trailfire LX
82 Sportfire (Electric Start)
83 Sportfire (Original Owner)
83 Liquifire
84 Sportfire
97 Indy 500 Liquid
1996 Polaris XLT Touring
