needle bearing info pls
Steven Rempel
Post by Steven Rempel »
I am planning to refresh some of my motors but need help find a source on where to get needle bearings for my kohler 295 2ax and my 440/21 motors. So right know i need a source and some way to confirm what sizes i need to buy/order. I would love to have a document of some kind telling me what size they should be. any help would be great.
That Girl Racing
Real Name: Peter
Re: needle bearing info pls
Post by That Girl Racing »
http://www.cvtech-aab.com is a great reference site for everything 2-stroke. They list all crank parts by dimension.
HoosierDeereMan
Real Name: Troy Miley
Post by HoosierDeereMan »
I have a old Central catalog that lists the wrist pin bearing info you are asking about.
Kohler K295-2/2AX uses a #1403 which is a 16mm x 20mm x 20mm needle cage bearing.
KEC 440 reed valve (serial #24 thru 33) uses a 1406 which is a 16mm x 20mm x 24mm needle cage bearing.
Hope this helps.
Troy
Steven Rempel
thanks guys for taking the time and helping
tks
