Custom 76 liquifire
- Real Name: Chris Farrell
Re: Custom 76 liquifire
Ok, I didn't like how high the xtra-10 set in the deere. I couldn't move it up in the tunnel any more with having track clearance issues. I still want to use a modern 121in track. I picked up a rear skid out of a jd trailfire. Many will say you can do that. But, with some metal, a welder and time, I feel I could do anything.
I had to but some solid steel spacers at the hardware store. Extended the rails out a 1/4in each side.
79 spitfire. 78 cyclone 440
76 liqufire 340. 80 liquifire
76 liquifire 440 x 2
I will be eliminating the front springs. I will be making some brackets and installing a modern coil over. Borrowed that idea from rainville's I-500 racer. I will be installing limiting straps on the front bar as well. I will be fabing some brackets in the next few days.
Looking great! You are probably going to need to add a set of front idlers to the skid like the Liquifire has, to avoid burning off the slides where the rails curve.
- SnowCrossMark
- Real Name: Mark
Consider that you are going to need more cooling capacity for that big motor, and you have not painted it yet, and
it is a 1976, get a repop Joe Rainville Dator hood. Yes, a Liquidator clone. Big attention getter out on the trails.
1977 340 Liquifire, 2 - 1978 440 Liquifires, 78 cc Clone(#35),
1997 Polaris XCR SE 600 (mistake).....
#400v
I seemed to have been a much better driver when my sled was slower.
#400v
I am planning on a dator hood. I will Be also instaling a 80-84 liquifire radiator up front.
I am seeing some through planning and very creative implementation of those ideas here.
Great work thus far. Keep it up.
I beating my head here. I need some ideas. I need to get the rear axle wheels extended out about a 1/4 of an inch. I usually can look at something and know what needs to be done. Kinda stuck at the moment.any advice would be helpful.
Extended out to the sides or back towards the snowflap? Larger diameter rear wheels then change your spacer to move them up 1/2 the difference so the bottom of the wheel is at the same spot.
The rear track adjuster axle. Square aluminum shaft. I need to pull the wheels out a 1/4 inch. Wheel size is not a problem.
- SnowCrossMark
- Real Name: Mark
Try the rear axle from the Extra-10. I had to cut slots into the axle to slide into the axle bracket. Now you can have three or four rear wheels eh.
#400v
#400v
I did try that. I need to grind down the square hole in the ajuster btackert a littlle more than an 1/8in. Problem is, the plastic square blocks are to big on the xtra 10. they hit on the rear suspension arm so it wont slide properly. I would also have to cut off the ajuster bolt block and move that down as well so the ajuster bolts will line up.
- SnowCrossMark
- Real Name: Mark
I just looked at my extra 10 and I understand the problem. Consider using a pipe/tube instead of the plastic blocks,then you can cut to fit.
#400v
#400v
Thats an idea. I will do that. i will post pics when i get it put together in the few days.
