Need ideas for handle bar pad repair on 340/s
69camaro
Real Name: Duane Gjerseth
Post by 69camaro »
My handle bar pad is in perfect condition except the pins have all pulled out on one side. Basically I need to take the nuts off and put the pins back in the other side. Any ideas of a epoxy, glue, or whatever will secure them back in the pad so I can secure the pad back in place so I can re-tighten the nuts. Thanks.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
69camaro
Re: Need ideas for handle bar pad repair on 340/s
Post by 69camaro »
Anyone?
75-340/s
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
Viktory2k1
Post by Viktory2k1 »
I thing epoxy (2 part) would work but you will not be able to pull them out again.
Current:
77 John Deere Cyclone 440
98 Yamaha SRX700
Past:
1968 Rupp GT300
1970 Evenrude Bobcat 440
1976 Arctic Cat Cheetah 440
1976 Ski-Doo TN'T Everest 440
1978 Yamaha Exciter 440
1979? Yamaha Enticer 300
1979? Yamaha Enticer 250
1987 Polaris Sprint 340
Wildfire II
Post by Wildfire II »
If you want it to look like a I500 sled use black duct tape or electrical tape!!!
69camaro
Post by 69camaro »
So on the the I-500 sleds they basically did that with the handle bar pad because they would pull apart racing anyway Ed? Viktory2k1, these are the pins that shouldn't pull out. The other end has the nuts on them so that would probably work good.
75-340/s
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
Vintagedon
Post by Vintagedon »
Duane, I would call Bill Tasky. He may know how to fix your sled.
69camaro
Post by 69camaro »
No doubt Tasky knows Don.
75-340/s
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
Norton
Real Name: Keith Bylin
Post by Norton »
69camaro,
I have been watching this post as I have a nice handle bar pad without usable pins too, for a CC LF. Using the sled as of late without any pad and waiting a great solution.
I went back and looked at my pics from the day, for my 340/s and Liquidator. The stock pad was used on my 340/s during the races. Factory pad would make cable and wire replacement harder under the clock so I suppose some removed it for that reason and just cut off foam and tape if needed. My Liquidator just had foam and duct tape for a handle bar pad. I race with a open face helmet and the foam was looked at as a possible tooth saver. Remember taping a Timex watch on the bars too. This 19 & 20 year old thought it was a good idea at the time.
keith
