suspension shocks
largecar04
Real Name: scott ohm
suspension shocks
Post by largecar04 »
Ok, so I'm back to working on my sleds and I'm still frustrated with one thing, the suspension shocks that are shot! After all of this time has anyone found a bolt on replacement gas shock for the trailfire and sportfire? I know a few of you have made some shocks work that didn't quite fit right but I really don't have time to do much more than bolt them on.
02 arctic cat zr 800 efi
02 arctic cat zr 800 cross country efi
Liquifried
Re: suspension shocks
Post by Liquifried »
I don't have the part #, but you can take the measurements off your original shock and find one at Dennis Kirk. I bought a few and I think they were Kimpex replacements for a Cat or Polaris, but the dimensions were the same. Seem to work fine and they were like $25 each.
Not cheap, but you can also find NOS from
http://www.imageenterprises.com/john-de ... r-sale.cfm
74 Evinrude Skimmer 400
82 Trailfire LX
82 Sportfire (Electric Start)
83 Sportfire (Original Owner)
83 Liquifire
84 Sportfire
97 Indy 500 Liquid
1996 Polaris XLT Touring
largecar04
I spent a little time in NAPA today and came up with a shock for 1939-1950 Chrysler/dodge and 1950-51 vw bugs that should work for $30. I ordered one and will be test fitting it Wednesday. I'll let you know!
largecar04
So I got the shock mounted today and it seems to work fine. I did have to trim the rubber bushings a bit but nothing major. I got a foot of bushing stock 5/8 x 3/8 and cut it into 1 1/4"lengths then drilled them to 7/16 and installed. The shock is about 3/4" longer when extended but I don't think it will be a problem. I've got some pics if I can figure out how to post them.
Liquifried
What is the NAPA part #
82 Trailfire LX
83 Liquifire
84 Sportfire
97 Indy 500 Liquid
largecar04
NAPA & O'Riellys part numbers are the same. It was $30 at NAPA & $27 at O'rielleys. Its a sensa-trac 5752
acesillini06
Real Name: Matt Cappel
Post by acesillini06 »
These gas shocks from NAPA fit great. part #5752. $30
trailfire runner
Post by trailfire runner »
What sled did you put this on?
Clay
Clay Gerfen
My Sleds
1 1978 Spitfire
1 1979 Spitfire
chriszildjian17
Real Name: Chris Farrell
Post by chriszildjian17 »
By the mounting if the shock, looks like a sprotfire,trailfire
79 spitfire. 78 cyclone 440
76 liqufire 340. 80 liquifire
76 liquifire 440 x 2
acesillini06
mounted on a 1983 Sportfire. and transfered bushings from old to new shock
Matt, was that a "press out" / "press in" bushing replacement?
jdrob
Real Name: Rob
Post by jdrob »
Matt you may have just become alot of guys new friend. :beers; :clap: Looks great.
Jdrob
acesillini06
largecar04 wrote:So I got the shock mounted today and it seems to work fine. I did have to trim the rubber bushings a bit but nothing major. I got a foot of bushing stock 5/8 x 3/8 and cut it into 1 1/4"lengths then drilled them to 7/16 and installed. The shock is about 3/4" longer when extended but I don't think it will be a problem. I've got some pics if I can figure out how to post them.
just like largecar said... you have to drill out the rubber on the new shock a little and burn out the rubber on old shock to get bushing out and install and RIDE! :sled:
