CCW recoil starter and cup. Clean $15
Liquifire:
Heads, Need cleaned up $20
Sportfire:
Chaincase $30
Drivers and shaft $20
Exhaust Shroud Piece $5
Fan Guard $5
Flywheel belt pulley $5
Trailfire:
2 Sets of cylinders, They will need replated $30 a set
3 sets of heads $10 per set
One crankshaft minus a bearing $40
Crankcase $40
Intake manifold, some corrosion $10
fan air scoop $10
LX recoil cup $5
Shroud set $15
Motor mount $10
Fan assembly $20
Fan Guard $5
Nice carb, not sure of jets $20
Carb with corrosion, $10
exhaust manifold $10
Misc:
2 Fire series Recoil starters, new rope, I even took them to the JD dealership so they have genuine john deere rope $15 each
One recoil cup$5
fire series tool box cover $10
3 flywheels, one without ring gear. $10 each
Secondary clutch, Rusty but could be cleaned up it isn't stuck $10
Brake rotor and pads $10
F clutch weights $15
Speedo drive $10
Prices Not incuding shipping. If you need picture I can email them.
Ryker
Fire series and CCW sled parts for sale
- Real Name: Ryker Carruthers
When In Doubt, Throttle Out
Re: Fire series and CCW sled parts for sale
Kawi starters and air scoop sold
Ryker
Ryker
