wtb comet cam arms B for 80 liquifire
sledder670
Post by sledder670 »
I need a set of three nos os very good used cam arms for a sled I am working on for another member. JD part number AM55172 or comet cam arm "B" any help is great thanks
Re: wtb comet cam arms B for 80 liquifire
I'll CK & see if I have any..
Grumpy
sledder670
OK Thanks really wanting to get this done so the guy can ride it this year.
It's not looking good. I have one more place up in the attic I can look, But??
sledder670
Is that the private stock?
nope, I already went through that, this is the last resort stock, LOL
OK I did find 2 & there probably is another one in the tube someplace, they are the fiber bushed ones but they are used & the bushings are wore but not through, I don't know if you can purchase the bushings or not?? I'm sure Deere never had them but the way it looks they may have been available from Comet through Kit number 208342 ( contains 3 replacements of a Special performance bushing that some comet weights had factory installed ) & the " B " weights had fiber bushings in them???? eBay item number: 111237119770 ??? Not cheap BUUUUUTTTTTT IF you need them?? There is at least 1/2 dozen of these kits listed on ebay, under Comet bushing Kit number 208342 or 208342A
Let me know if you want me to dig further, also these 2 I have are 45.01 & 45.12 grams. If I remember right, I walked up the stairs from the reloading room since then & forgot what they were, LOL
sledder670
Thanks Kenny, I guess I never checked to see if I could get just the bushings. Between all the parts i think i can make one good set.
So do you want me to keep digging for the other arm? do you want the 2 I found? Or are you going to rebuild the ones you have with new bushings? if you do rebush some let me know how that works out as I have a bunch that need new bushings..
sledder670, Are you following the post in the Kawasaki Tech Talk Portion under " Identify 'B' clutch weight "?? Are the new 102's with the allen wrench head weight bolts 1/4" or 5/16th" or is it only the 108's that use the 5/16th" bolts??
sledder670
I don't need the arms. The 102c I have all seen are 1/4" bolts for the can arms
OK no problem
ICCSF 108 wrote: if you do rebush some let me know how that works out as I have a bunch that need new bushings..
I rebushed the 2 sets that I'm currently running. It was pretty straight forward. Pressed out the old bushings then pressed in the new bushings. Didn't have any issues getting them through a local dealer, but they seemed a little pricey to me.
Sent from my Motorola RAZR MAXX using Tapatalk
skoalmint
Post by skoalmint »
Hey sleder670, I have a NOS set. Brock
sledder670
I just ordered the bushings. Thanks
