Pulling flywheel
- Danzig
- Real Name: Paul File
Re: Pulling flywheel
- Danzig
- liquitisplit80
- Real Name: Roy
Now, see how easy that was??
A picture is worth a thousand words.
Thanks Paul!!!
Thanks Paul!!!
'78 Spitfire
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
Still ridin' the New Breed!
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
- Danzig
I would advise not using a pipe to hold the clutch still when tightening the puller.
You can break a tower that way.
Best to use an impact wrench and then you can hold it with you hand.
- Danzig
Thanks Todd...I was going to say that too...but I figured we were past that level of ignorance here !
In the flywheel video he took off the fan blade.
Don't ask me why......
Did you notice all the bolts were already loose?
Just like those car shows on Saturday afternoon where they take a bumper off a 71 camaro in 30 seconds.
Yeah right!
Yeah right!
- Danzig
Reminded me of myself......
That Girl Racing
- Real Name: Peter
Just my opinion but............that is not really correct. Again there is a gap between the fingers and the flywheel. That is when the 6mm bolts and threads get destroyed. The torque is being transferred to the loose threads and not the taper. Use the right tools the right way and the job will be done properly, safely and without damaging any parts. Every time!
That Girl Racing
- Real Name: Peter
Another thing. Never fully remove the flywheel nut. Back it off just enough to let the flywheel pop.
WOW, I didn't think taking off a flywheel could be so hard? & take so many posts..
This is a good example of why " if your going to be working on your sled you should have the proper Service Manual "
By the way this wasn't ment to offend anyone, just to make a point..
Grumpy
Grumpy
Good point Peter.
I have seen clutches and flywheels explode off the shafts.
Sometimes extremely loud and bounce off the bellypan.
horntwister
did you take the nut off
- SIIaCanuck
This will bring mutterings of, 'I told you so!' Deserved I admit.
Diesel pump puller didn't have holes that lined up . . . soooo:
Took all of 5 mins from opening the parcel from Rec Supply.
Don't cheat, buy/borrow/etc the right tool.
Or else you'll get Peter telling you you're a buffoon, and he'll be right!
Stew
'80 440 Liquifire
'72 292SS Elan
'74 294SS Elan
'80 440 Liquifire
'72 292SS Elan
'74 294SS Elan
- Sprailfire340
Amazing how much time and money one can save using the right equipment the first time. I know I've tried the "make work" tools before and often end up making a bigger mess than the one I was originally trying to fix. Congrats on your new found wisdom and thanks for taking the time to post pics.
