wanted asap 83 snowfire carb
sledder670
Post by sledder670 »
Working on a sled for another member and it has the wrong carb on it. Not sure how well they work when the slide is installed backwards cause the pin and idle screw are on the opposite sides of the right carb. The cutaway side was toward the motor. Real good head scratcher. Anyway need a 30mm and correct jetting and throttle slide as well, I have new needle and seat for it. Sled is an 83 snowfire not sure if the spitfire carbs are the same or not. Thanks for any help. Wheels
sledder670
Re: wanted asap 83 snowfire carb
Anything?
monte44
Post by monte44 »
I have one off a sprintfire. With different jetting it might work?
sledder670
Ya I have a sprint also. Those are a 32mm and I need a 30mm to keep it original. Thanks
