liquifire 340
liquifire 340
does anybody now the correct sparkplug for 76 340 liquifire.also want to raise clutch engagement.can i just change spring?thanks
liquifire 340
THANKS FOR THE INFO I JUST WANT TO RAISE ENGAGEMENT SO IT COMES OUT OF THE HOLE BETTER.
liquifire 340
WHERE ON EARTH ARE YOU GETTING N-1 CHAMPIONS????????????
I can't find em anywhere, just old NGK's....
-Matt
-Matt
liquifire 340
i am running NGK plugs number B9ES they have the proper depth and plenty spart. With that same modle do u know where i could order reed valves
liquifire 340
I have seen the reed valves on ebay. What makes you think you need to replace them.
