carb help?
carb help?
So this is the carb that came with the 1980 Trailfire 340 unattached. What's gonna be the best way to soak this or clean it in, what chemical or process. I don't have a parts washer unfortunately.
SIIaCanuck
Re: carb help?
Post by SIIaCanuck »
If you have anyone near you that has an ultrasonic cleaner, that's where I'd start.
Stew
'80 440 Liquifire
'72 292SS Elan
'74 294SS Elan
ljm
Real Name: Lloyd
Re: carb help?
Post by ljm »
Ultra sonic cleaner would be the best.
I know it sounds strange. But soaking over night in Pine Sol will do wonders for it. Completely disassemble it, put all the pieces in containers, put enough Pine-Sol in each container to cover the pieces, let soak all night. Remove the pieces rinse with water, blow dry with compressed air, reassemble.
This has worked wonders for me.
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Re: carb help?
Pine-sol huh? straight or mixed with water. dunk the whole carb as well as all pieces? any other chemicals I could use that work well, just trying to get an idear
ljm
Real Name: Lloyd
Re: carb help?
Post by ljm »
Straight Pine-sol put the whole carb in after you disassemble it. Carb and all the pieces. You will see it start to bubble.
Several Deere's
Several Kawasaki's
ACSCC #1534
Re: carb help?
Solvents work also but some will attack the rubber/plastic parts.
Kerosene works. A tooth brush and a small pick will get the crud out of corners.
Overnight soaking works best. :think:
Re: carb help?
ok I might give the pine sol a whirl thanks!
Re: carb help?
Trying the pine-sol soak!
croyturbo
Real Name: Chris
Re: carb help?
Post by croyturbo »
How did the pine sol woork?
Chris
Re: carb help?
Pine Sol worked pretty nice
