Sprintfire Track
T White
Sprintfire Track
Post by T White »
Hi Guys,
I'm going to re-cleat my spare Sprintfire track, is it OK to use aluminum pop rivets or do I need to use steel.
Tom
Re: Sprintfire Track
Hi Tom,
I would not use aluminum. Although Cat used pop rivits, Deere always used solid steel rivets originally. Many of us use the "threaded rivets" that should still be available. You can get them with the same size head, but with a threaded body and lock nut. My second choice to those would be a high strength steel rivet. A pneumatic rivet gun makes installing those a snap.
I hope this helps,
jd_decalguy
Post by jd_decalguy »
Tom, Use the steel for sure.. & like Joe said a air rivet gun will help alot...
Grumpy
Chris Dotzler
Palisade, MN
