Trying to find the part I need which isn't likely I've been told so prob. looking for a tunnel for my '78 LF. Cyclone tunnel will work too right?
PArt I need is Deere part # AM54204. Its the alum braket that hold bottom of steering rod in place to the tunnel.
'78 LF or Cyclone Tunnel
'78 440 Liquifire - (2)
'80 440 Liquifire
'81 440 Liquifire
'80 440 Liquifire
'81 440 Liquifire
Re: '78 LF or Cyclone Tunnel
The lower steering bracket AM54204 was original on the 77/78 Cyclone/Liquifires and a replacement on the 76 Cyclone / Liquifire. I do not have one but someone probably will, just give it a day or so.
I'm parting out a 77 liquifire if its the same.
Yes '77/'78 LF should be the same from what I know. I'll send a PM to see what we can come up with.
'80 440 Liquifire
'81 440 Liquifire
'80 440 Liquifire
'81 440 Liquifire
Check the bulkhead for cracks when you remove the bracket. They are known to crack.
