WTB Secondary Shaft 84 Liquifire
gumbofarmer
Post by gumbofarmer »
I need to find a M69234 Secondary shaft. NOS or good used.
Thanks, Maynard
Re: WTB Secondary Shaft 84 Liquifire
Maynard, I don't think we have one but if we do shall we bring it to RWTC?
gumbofarmer
Yes, that would be great Don!!
427cobra
Real Name: Eric
Post by 427cobra »
I would have a good used one.
If Don cant get you one let me know.
Thanks!
smitfire
Real Name: Dustin Smit
Post by smitfire »
Why are these a different part number than an 80? 81?
gumbofarmer
I was wondering the same thing.
smitfire wrote:Why are these a different part number than an 80? 81?
Different secondary for the 1- 3/8" M69170 belt, so the shaft is longer.
Farmer
Post by Farmer »
Just to let everyone know that secondary from a 80-81 will work on the later machines or vice versa. The only thing that is different is the material bushings are made from and the thickness of the limiting washer that stops the secondary from opening up as far. It has nothing to do with how far it closes for the belt width. I disassembled both of them and every part is the same. I don't have a early shaft to measure the machined end to compare too but assume it must be different to make up for the wider belt on later models. Maybe more shims on a old shaft will do the same thing??? To sum it all up the secondary is exactly the same early-late other than bushing material used and thickness of limiting washer. That is why the part numbers are different.
jdjock
Real Name: Tom Schuster
Post by jdjock »
Farmer, you hit the nail on the head. I just reread the original service bulletin. The washer is the key. Tom
gumbofarmer
Thanks 427Cobra, I send you a pm
Maynard, a no go here in Churubusco. Sorry but still looking forward to seeing you later this week.
Farmer has this shaft thing doped correctly. The newer shaft is supposed to be 20% stronger and has an increased shoulder to accommodate fewer washers while the overall length is identical. The stationary sheave on 82 and up machines has longer towers to accommodate the wider belt, so I would guess that swapping them would require using the appropriate belt. Perhaps I should have consulted the book first. :bonk:
RLFollman
Post by RLFollman »
Maynard - I have a nice used shaft and secondary clutch from an 81 Liquifire. If you're going to RWTC, let me know ahead of time and you can stop by my place on the way and pick it up.
Randy
gumbofarmer
Thanks Randy we are on the way but we go through Duluth.
gumbofarmer
Randy I have sent you a PM
