what should the length of the pickup tube be inside the gas tank,and should it lay in front of the glove box or run down the side of the tank and glove box,this is on a 79 trailfire
pulled it all apart and the tube that was off and pretty much brittle and fell apart,someone before me used the clear fuel line as pickup tube,the check valve ,the screen was gone and so was the check ball.
also changing crank seals, any thing special i should know when changing them, they put on dry or with some kinda lube?
thanks dave
fuel pickup question. crank seal question.
75 800 440
79 TRAILFIRE 440
79 KAWI INVADER 440
06 SKI-DOO MACH Z 1000CC
79 TRAILFIRE 440
79 KAWI INVADER 440
- Real Name: Bob Amber
Re: fuel pickup question. crank seal question.
I think the pick up line lays across the front of the tank from right to left and there might be a slight channel if I remember right. 12"- 15" is probably plenty.
I don't use any lube to put them in, but I always split the case and set them in. But I have seen some just push them in from the end. Never seen lube used.
You should lube the seal lips (the part that touches the crank) with grease when you assemble the lower end. This prevents friction between the shaft and the dry rubber seal from burning the lips.
1980 Liquifire
1983 Trailfire LX
Others
67 Olympique
72 Elan single
72 Elan 340 TNT Swap
74 Elan Twin
78 Elan Deluxe
87 Phazer Deluxe
89 Formula MXLT
1983 Trailfire LX
Others
67 Olympique
72 Elan single
74 Elan Twin
78 Elan Deluxe
87 Phazer Deluxe
89 Formula MXLT
I can't disagree. Makes perfect sense and I will follow this suggestion from now on.
yea theres a channel on both sides of the glove,stoage box.
75 800 440
79 TRAILFIRE 440
79 KAWI INVADER 440
79 TRAILFIRE 440
79 KAWI INVADER 440
