151" Liquifire
toocheaptosmoke
151" Liquifire
Post by toocheaptosmoke »
This is for Horicon Joe. :mrgreen: Still have a few things to finish before I drag it back out of the shop and get some better pics, took it to a hill climb race last sunday and left a lot of loose ends just to get it running.
JDXspec
Real Name: Dustin
Re: 151" Liquifire
Post by JDXspec »
:shock: That looks like it could be a handful.
mfd1221
Real Name: Jim Cieply
Re: 151" Liquifire
Post by mfd1221 »
That's pretty cool
Re: 151" Liquifire
:shock: :shock: :shock:
Re: 151" Liquifire
Looks like it is doin' 80 just sittin' there.
NICE!!!! :letitsnow:
By the way it did now here today.
fastl82vette
Real Name: Greg Cyrocki
Re: 151" Liquifire
Post by fastl82vette »
DANGGG!!! :popcorn:
-Greg
'86 Kitty cat
'77 Cyclone SOLD
'84 Snowfire
'88 Yamaha Sno Scoot
'71 Massey Ski Whiz Special
sledder670
Re: 151" Liquifire
Post by sledder670 »
Is that a 617 or 670 in there. I was considering doing a 136" renegade liquifire. I parted out a 96 skandic long track and I could almost just rivet the tunnel to the liquifire bulk head to it.
toocheaptosmoke
Re: 151" Liquifire
It's a 670, not an H.O. though.
Re: 151" Liquifire
All I can say is holy moly wicked
Re: 151" Liquifire
sledder670 wrote:Is that a 617 or 670 in there. I was considering doing a 136" renegade liquifire. I parted out a 96 skandic long track and I could almost just rivet the tunnel to the liquifire bulk head to it.
You'll need to add on to your shop! :lol22:
Horicon Joe
Real Name: Joe Wanie
Re: 151" Liquifire
Post by Horicon Joe »
Looks like fun ...... More pics! I want to see the motor mount. :D
Joe
idMXLT
Real Name: Stephen
Re: 151" Liquifire
Post by idMXLT »
You are officially my hero now........
And yes more pics please!!! :pray:
1980 Liquifire
1983 Trailfire LX
Others
67 Olympique
72 Elan single
72 Elan 340 TNT Swap
74 Elan Twin
78 Elan Deluxe
87 Phazer Deluxe
89 Formula MXLT
Horicon Joe
Re: 151" Liquifire
What drive wheels did you use?
toocheaptosmoke
Re: 151" Liquifire
I'll get some better pics of the engine mounting, I was making a video documentary for a while but then I started running out of time and barely got it together in time to race. :bonk:
The engine is attached to a TX 340 motor plate, bolt patterns are the same. Then I re-formed it in the press a bit and mounted it to the tunnel and a couple spacer blocks down in the bellypan.
To make the track fit, I had to use the doo chaincase, drop and roll it, press some kawasaki 8 tooth drivers onto the doo driveshaft, remove the front heat exchanger and cut the pinch seam, then chop and section the top of the tunnel.
toocheaptosmoke
Re: 151" Liquifire
Not sure why the pics are getting cut off on the right side?
Things were a tight fit, the hammer was a vital part of this build. :wink: The main donor sled was a wrecked/blown up '93 ski-doo mach 1.
Used the stock jackshaft location, went to 12" center distance on the clutches. Must of had the engine in and out 50 times mocking up the mounting position to get the alignment and orientation right.
Brake rotor clears the tunnel by, well, not much. :mrgreen: Shaved down the one brake pad so it would clear. The jackshaft also just barely clears the newly formed tunnel. Also had to move the steering column over about 1/2" to clear the mag side carb.
I started chopping up the original y-pipe, but the socket joint was pretty well sacked out. In the search for a replacement I found out that some model sleds came with an angled mounting position to begin with. So, I got one of those and ran it upside down.
Had to cut reliefs in the motor plate to clear the carb bowls. Carbs are sitting at about 25* so I adjusted the floats to compensate.
Lower motor mounts are a couple chunks of square tubing I found in the scrap pile. Coolant hose just barely fits in there. Also added in a torque arm to help control the beast.
Here you can see where the tunnel arches up to clear the track. Yes, that is duct tape sealing up some of the gaps to keep snow out of the belly pan.
Gratuitous use of zip ties. :dance:
:mrgreen:
Had a new aftermarket windshield I tried to sell for a while, good thing it never did, so I chopped it. Then took a cue from the stones and painted it black.
Seat is from an '83 TXL cross country, gas tank a citation 4500, all sourced from the random parts pile out back.
Precision skis converted to leaf springs
Looks stock to me. :think:
Doo gauges in the original pod. Had to run the coolant lines over the tank because the exchangers are so far back in the tunnel.
Silencer is the cheapest glasspack I could get from Summit, like $11. I uses some parts of the old can to make it fit, even used the stock exhaust outlet.
Tunnel was extended about 16" and was accomplished by splicing and dicing the ass end of a phazer onto it. The suspension is a couple of 1980's polaris skids grafted together, then moved back about 5" within the tunnel.
