Crank Seal Application Chart
I have posted a crank seal application chart, with links pointing to the correct item on New Breed Parts:
http://www.newbreedparts.com/newbreed/crankseals.html
Let me know if anything looks off.
lwb140
Real Name: Wade bennett
Re: Crank Seal Application Chart
Post by lwb140 »
matt that's awesome !! I think the ccw and kioritz motors don't use the 1302r its just the 1302 ,no ribs lol wade
My supplier does not carry the OS1302 on it's own for some reason, so the R version is the only one available to me.
That is how all the trouble started .... with a rib. :silenced:
Nice quick reference!
ljm
Real Name: Lloyd
Post by ljm »
Excellent reference Matt
You could add to the Kawasaki list
440 Drifter is the same as a Sportfire and a 340 Drifter is the same as a Traifire
Several Deere's
Several Kawasaki's
ACSCC #1534
zrt man
Real Name: Donald Matthews
Post by zrt man »
I noticed that the liquidator is not mentioned in this list matt. Maybe you cant get them seals for the liquidator through ur supplier. This would be a great quick reference to have in the shop to print off and put on the wall. If the sizes of each seal were posted with your part number then that would be great too.I did notice if you click on the part number of any seal on the chart you have now that it will take you to the new breed parts store and show the seal size there. If a chart like this didnt take much time to make and add to the tech section then it would be great to have. thanks donald
1976 cyclone 440
1977 cyclone 340
1978 cyclone 340
1978 liquifire
1999 zrt 800
2016 renegade 600 sport
If someone has the Liquidator seal size handy, let me know and I'll check. I could easily add the sizes to the chart.
Lloyd, I had intentions of adding the rest of the Kawasaki's as well. Thanks!
Sprailfire340
Post by Sprailfire340 »
Try this...
Liquidator MAG & PTO M66733 30mm x 72mm x 10mm (OEM 8mm) non-ribbed
501305 / OS1305
:sled: ME
Updated with seal dimensions, the Liquidator seals, and some of the Kawasaki seals.
zrt man
Post by zrt man »
Thanks matt.The crank seal chart looks great.
1976 cyclone 440
1977 cyclone 340
1978 cyclone 340
1978 liquifire
1999 zrt 800
